Have you checked your voltage regulator ?
Check the battery voltage before and after starting the engine to determine if the battery voltage increases. Refer to the Normal Charging System Voltages chart.
Terminal "A" "S" "I" "Alt B+" "Batt"
"Eng to bat grnd"
Key OFF (12V) (0V) (0V) (12V) (12V)
0V
Key On - Engine Off (12V) (0V) (1-3V) (12V)
(12V) (0V)
Engine Running (12V- 15V) (6-8V) (12V- 15V) (12V-15V) (12V- 15V) (0V)
If you have an "Advance Auto Parts" near your location they will check your Alt. - Battery - Regulator and let you know what's going on.
Good Luck;
Rick
Dec 1, 2009 at 12:15 AM
