1997 Ford Explorer cam sensor
108,000 MILES • V8 • AWD • AUTOMATIC
CHASEY
Hi i have a 97 explorer with the 5.0 v8 the cam sensor /synconizer is chirping -can this be fixed by just replacing the sensor or does the entire unit have to be replaced -or is it poosble to oil it from the top to make it stop -it is getting very loud-Thanks
Oct 20, 2010 at 10:28 PM
  • 110,246 POSTS
Are you sure it is the sensor and not a belt issue?
Oct 21, 2010 at 12:20 AM
WRENCHTECH
  • 20,760 POSTS
No, the noise is going to be coming from the synchronizer assembly and it will all have to be replaced. Be VERY careful removing this as it has to be timed and if it is not marked very carefully before removing, it will require a pretty rare special tool to get it positioned correctly again.
Oct 21, 2010 at 12:21 AM
CHASEY
[quote:78ff9c5295="Jacobandnickolas"]Are you sure it is the sensor and not a belt issue?[/quote:78ff9c5295] no its the sensor i replaced the belt all the tensioners the water pump and the alternator=
Oct 21, 2010 at 1:17 AM
CHASEY
[quote:dd8284066d="Wrenchtech"]No, the noise is going to be coming from the synchronizer assembly and it will all have to be replaced. Be VERY careful removing this as it has to be timed and if it is not marked very carefully before removing, it will require a pretty rare special tool to get it positioned correctly again.[/quote:dd8284066d] Thanks saved me alot of time -I found a replacement part on ebay sells the part with a tool to align prpoerly -Thanks again
Oct 21, 2010 at 1:44 AM
WRENCHTECH
  • 20,760 POSTS
Read the instructions carefully before removing the old one.
Oct 21, 2010 at 1:46 AM
  • 110,246 POSTS
Wrenchtech, can you PM me.
Oct 21, 2010 at 3:51 AM
