1997 Ford Explorer Brake light repair
GRASSHOPPAH
Electrical problem
1997 Ford Explorer
I just want to make sure I don't break anything when I replace a tail light bulb, there are 2 screws on the tail light cover, but I'm not sure if I should just use a flathead to pop it off or if there is another step before I crack this thing literally!
Sep 17, 2009 at 8:38 AM
  • 110,248 POSTS
THere should be 2 screws on the inside of the hatch assembly. Have you tried to remove them? Other than that, it should be hinged.
Sep 20, 2009 at 7:04 AM
