1997 Ford Explorer bearings pieces in transmission pan
94,300 MILES • 6 CYL • 2WD • AUTOMATIC
LITTLEOLDMEEVE
My transmission started delaying in shifting reverse and drive until it warmed up. My o/d light was flashing. any way I took it to a transmission shop. They show me the pan it had piece of bearlings and little pins. I do know the difference from a little metal but these were part piece. I was told that my transimission needed to be rebuild. How much do you thing it should cost to rebuild? I also need the MLPS and the O/D sensor which I already knew about because of the codes.
Thanks Eve
Feb 22, 2008 at 2:32 PM
MERLIN2021
  • 17,250 POSTS
Rebuilts swing wildly depending who does the work, I got prices from 1200.00 to 2500.00 for a Sable tranny. Shop around.
Feb 23, 2008 at 2:44 AM
