1997 Ford Explorer 4wd won't disengage
160,000 MILES • 6 CYL • 4WD • AUTOMATIC
GIDEONTUCKER
was going to replace u joint today (worn) but before i started that my explorer ended up not being able to shift out of 4wd... checking fuses what else needs to be checked all suggestions welcome. thanks
Oct 19, 2009 at 1:45 AM
  • 110,248 POSTS
Are you getting power to the actuator on the transfer case?
Oct 26, 2009 at 12:22 AM
