1997 Ford Explorer 4wd dash lights flashing
81,000 MILES • 6 CYL • 4WD • AUTOMATIC
DON RUSH
In previous questions on this topic, you say to look at the stored fault codes in the drive train control module. Is this the same as the OBD2 connector (vehicle computer) or is there another location where fault codes are stored? There are no codes stored from the OBD2 connector even though the 4wd lights flash (6 times every 2 minutes). I cannot find info on 6 flashes in the Ford workshop manual for this vehicle.
Oct 14, 2010 at 4:30 PM
  • 110,251 POSTS
You need a scanner designed to read the other codes. A basic OBD II scanner will only read engine codes.
Oct 15, 2010 at 1:20 AM
