1997 Ford Explorer
173,000 MILES • 6 CYL • 4WD • AUTOMATIC
RANDALLLG
goes good in 1st and 2nd gear but wont go in drive or reverse only moves slighly at 3500 rpms
updated 4/9/10
Yea check engine light has been on for long time even b4 it acted up.. How do i fix that bad shift solenoid n how much will it cost?
Mar 23, 2010 at 3:15 PM
  • 110,251 POSTS
Has the check engine light come on? It sounds like a bad shift solenoid.
Mar 25, 2010 at 3:37 AM
  • 110,251 POSTS
Before doing anything, have the computer scanned for trouble codes. Chances are the computer knows what is wrong with the transmission. Many parts stores will do it for free.
Do that and let me know what you find. Also, if it is a shift solenoid, the computer should identify which one it is. You need to remove the pan to access the solenoid. Parts should be under a hundred dollars.
Let me know what you find.
Apr 9, 2010 at 12:47 PM
RANDALLLG
the overdrive light flashes its been flashing awhile put some lucas oil transmission slip in n it helped a lil for a mile drive then acted up again
Apr 11, 2010 at 4:00 PM
  • 110,251 POSTS
It may just be the clutches are bad. However, if the light is flashing, I would suggest having the computer scanned to see why the OD light is flashing.
Apr 11, 2010 at 10:34 PM
