1997 Ford Explorer
SANDRABUCKMAN
Electrical problem
1997 Ford Explorer Four Wheel Drive Automatic
my speedometer does not work, all the other guages work except that. but there is a toggle switch hooked up to start it up after you turn the key over could that be getting in the way? I did change the speed relay.. I don't know what else to do...
Feb 22, 2010 at 8:32 PM
  • 110,248 POSTS
What toggle switch? How was it wired? And when you say speed relay, are you refering to the vehicle speed sensor (VSS)?
Feb 23, 2010 at 5:33 AM
