1997 Ford Explorer
245,000 MILES • 6 CYL • 2WD • AUTOMATIC
BARKLEY08
the only pump was clogged up and it wasnt gettin any oil to the top of the motor, it had no oil pressure. i drove it for about 10 miles to make it home. i got home and took the oil pan off and cleaned the pump, i put it all back together and it ran like it use to and had oil pressure. then when i put it in gear there is a really loud knockin noise, i have no idea what it is.
Jan 12, 2010 at 11:30 AM
  • 110,248 POSTS
If there was no oil pressure for 10 miles, chances are you wiped out the rod or main bearings in the engine. Does the sound seem to come from low in the engine?
Jan 14, 2010 at 12:53 PM
BARKLEY08
yeah the noise seems to be comin from the oil pan, it still has the power and everythin just that loud knockin, how long do u think it will last?
Jan 16, 2010 at 4:02 PM
MUSTANG8993230
you beat the motor its basically gone no cure but to rebuild.never drive when oil pressure is low .
Jan 17, 2010 at 10:45 AM
