Probably that you need new brakes. :)
The brakes are engaged by hydraulic pressure, so as the brake linings wear, the fluid level drops. If the fluid drops below a certain level, the warning light will come on.- It is also possible that there is a leak in one of those hydraulic compontents - master cylinder, caliper, brake hose, or wheel cylinder. Have you noticed any noise when braking? or seen any evidence of brake fluid on the ground? - and how is the fluid level?
Oct 13, 2008 at 3:34 PM
