1997 Ford Explorer
JAVIMELGAR71
Engine Mechanical problem
1997 Ford Explorer 6 cyl Four Wheel Drive Automatic
My 1997 Ford Explorer will not turn on. The other day i was dropping off a friend when the ca turns off on me, i tried turning it back on but it didnt. The engine sounded like it wanted gas, but i had 1/2 a gallon. So i think its the fuel pump cutoff swicth, but i dont know where its located? Or if thats the problem? (I checked the fuses and the battery)
Jan 23, 2009 at 2:49 PM
JDL
  • 16,098 POSTS
https://images.2carpros.com/forum/automotive_pictures/170934_bump_switch_2.jpg
That's all I found for the location of the inertia switch. Have you done any basic testing, like, with the vehicle cranking, check for spark at the plugs?
Jan 24, 2009 at 3:29 AM
