1997 Ford Explorer
PONYLOVER77
Heater problem
1997 Ford Explorer 6 cyl Automatic
I am having trouble with my heater. I have checked the thermostat and it is coming to the normal temperature. The heater blowers work fine. The two tubes coming and going from the heater core are working (they feel warm to the touch when the car gets to normal temp.). The problem is I have no heat. It blows out cold air. Where or what should I look at. I have anti-freeze in the radiator. PLEASE HELP!
Nov 21, 2008 at 10:41 AM
BLUELIGHTNIN6
  • 16,542 POSTS
This could be a faulty water pump going out. Do you notice any noises when the heater is turned on?
You may also want to check your fuses and relays.
Nov 21, 2008 at 1:27 PM
