1997 Ford Explorer
MILES GLOVER
Heater problem
1997 Ford Explorer 6 cyl Four Wheel Drive Automatic
suffient heat' doesn't get hot enough
Sep 27, 2010 at 9:41 AM
WRENCHTECH
  • 20,760 POSTS
With the engine at full operating temp, locate the 2 heater hoses where they go into the firewall and feel them to see if they are both hot to the touch.
If you find that they are both too hot to hold, then the heat in that vehicle is controlled by a blend door that regulates heated air flow. it is operated by an electric motor/actuator. The problem can be that the actuator is stripped or inoperative or the door itself could be damaged. This is what needs to be determined by examining the actuator and see if it is responding to heat change commands or not.
Sep 27, 2010 at 10:08 AM
