1997 Ford Explorer
146,700 MILES • V8 • AWD • AUTOMATIC
GEEBANG
what does it mean when the brake light is on and the brakes dont stop on time
Oct 8, 2008 at 3:18 PM
KERENSELF
  • 54 POSTS
Probably that you need new brakes. :)
The brakes are engaged by hydraulic pressure, so as the brake linings wear, the fluid level drops. If the fluid drops below a certain level, the warning light will come on.- It is also possible that there is a leak in one of those hydraulic compontents - master cylinder, caliper, brake hose, or wheel cylinder. Have you noticed any noise when braking? or seen any evidence of brake fluid on the ground? - and how is the fluid level?
Oct 13, 2008 at 3:34 PM
