1997 Ford Explorer
1997 FORD EXPLORER
THICKS123
1997 Ford Explorer 6 cyl Two Wheel Drive Automatic
my exploer will crank over but not start i have replaced the wiers and coil.There is no fire comming off the coil what could my problem be
Mar 16, 2010 at 3:19 PM
DAVE H
  • 13,384 POSTS
Replace the crankshaft position sensor
The EI (high data rate) system consists of a Crankshaft Position (CKP) sensor, and Ignition Control Module (ICM).
The EI system operates by sending crankshaft position information from CKP sensor to ICM. The ICM generates a Profile Ignition Pick-Up (PIP) signal and sends it to the PCM.
The PCM responds with a Spark Output (SPOUT) signal containing advance or retard timing information back to the ICM. The ICM processes the CKP and SPOUT signals and decides which coils to fire. Also, the ICM generates an Ignition Diagnostic Monitor (IDM) signal to PCM, which is used to provide a tach output signal and indicate a failure mode if detected.
The CKP sensor is an electromagnetic device that senses movement of a 35 tooth wheel, located behind the crankshaft pulley. Each tooth is positioned in 10 degree increments with an empty slot (missing tooth) located BTDC. The detection of the missing tooth is what enables the PCM to identify crankshaft position and initiate correct firing order.
The ICM is a microprocessor with coil drivers. ICM strategy controls spark timing and coil firing. The ICM turns coils on and off at the correct time and in proper sequence, based on information from CKP sensor and a pulse width modulated signal (SPOUT) generated from PCM. The ICM receives CKP sensor and SPOUT signals and produces PIP and IDM output signals, which are sent to PCM.
The PCM receives ignition ground and PIP signals from the ICM, and then generates a SPOUT output signal based on engine speed, load, temperature and other sensor information. An IDM signal is received from ICM to determine if an ignition failure mode should be recorded.
The coil is turned on (coil charging) by ICM, and then turned off, firing 2 spark plugs at once. One plug is fired on the compression stroke; the other plug fires the mating cylinder, which is on the exhaust stroke. On the next cycle, firing strategy is reversed.
Mar 17, 2010 at 5:15 AM
