1996 Ford Explorer Truck Bucks
SPEEDYED69
Engine Performance problem
1996 Ford Explorer 6 cyl Four Wheel Drive Automatic
I have replaced all the things that I have been told could be the problem. i have replaced the crankshaft position sensor, the egr valve and the mass air flow sensor and it is still bucking when i hit 80 mph. please help me
Aug 7, 2010 at 3:13 PM
  • 75,988 POSTS
Lack of acceleration,chugging,hesitating,bogging,misfiring etc. could be caused by one of the following below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Aug 7, 2010 at 3:31 PM
SPEEDYED69
ok apparently you know nothing about a 96 ford. i do not have a cap and rotor. it is just a coil. i siad it was bucking at 80 mph, everything else is fine. please do not provide such a general answer. if you are unsure, do yourself a favor and maybe ask someone before you answer my question. i do appreciate the speedy response, but not satisfied at all.
Aug 7, 2010 at 3:34 PM
  • 75,988 POSTS
Note:If it doesn't apply disregard it. Do you know exactly what I meant by this-am not a magicman
Maybe if you start troubleshooting the general answers that I gave you -you might get somewhere instead of coming back and telling me you don't have a cap and rotor, I was prepared to help you all the way to fix your problem now I've changed my mind-Good Luck
Aug 7, 2010 at 6:07 PM
