1996 Ford Explorer Tapping when on
311,000 MILES • V8 • 2WD • AUTOMATIC
CHICHI0713
A/C sounds like lifter tapping when turned on, kinda like it is continually cycling. I did recharge with canned refrigerant 134a and it blows cold just tapping will drive you crazy. I'm not Mz. Goodwrench but I know that it needs something maybe compressor oil? How do I put that in and where? However the tapping noise is about to send me over the edge. Yes I put gloves on so I don't mess up my manicure and do all the maintenance on my truck and for as many miles as it has and most everything has been replaced or re-built it is very reliable.
Please help. chichi0713@msn.com Thanks Chichi
Jun 23, 2008 at 5:35 AM
DOCFIXIT
  • 18,828 POSTS
Open the hood look at the clutch is it cycling?
Also, can you get a long screw driver or something metal on the comp. a put your ear to it and hear noise ?
You can put oil in system there are charge cans with oil only problem there is if you don't have a high side gauge hooked up bad things can happen.
Let me know
Jun 23, 2008 at 6:02 AM
