1996 Ford Explorer suspected electronic problem with Transm
BODUKE5051
Transmission problem
1996 Ford Explorer 6 cyl Four Wheel Drive Automatic
this is a 96 eddie bauer explorer 4x4, aod. few days ago, speedometer started jumping erratically, and trans would slip out of OD on highway when warmed up. couple of days later, speedo does not work at all, o/d light on cluster is flashing, transmission shifts erratically & hard whether warmed up or not, and at all speed ranges. changed fluid & filter, no shavings or debris in pan, fluid smelled old, but not really burnt. I'm suspecting one or more of the electronic components have failed, but not really sure.
Dec 20, 2009 at 8:12 AM
  • 110,251 POSTS
Has the check engine light come on? The problem sounds like an issue with a vehicle speed sensor.
Dec 22, 2009 at 11:59 PM
BODUKE5051
No, the C.E.L. did not come on. took to a shop a few days ago, & found that for some reason the speedometer drive gear in the transfer case is getting chewed up, causing the problems. looking to swap the transfer case once the recent snow melts. thanks though.
Dec 25, 2009 at 4:34 AM
