1996 Ford Explorer shifting
274,000 MILES • V8 • AWD • AUTOMATIC
NATE49349
i have replaced the tps sensor like 4 times and the shifting problem is still their. When it worms up and after it is warmed up when you stop and then go push on the gas it acts like the tranny aint even their but if you wait long enough when puching the gas down it will kick in to gear. Also when I go to slow down it makes a klunking noise to but only when the vehicle is hot.
Aug 17, 2010 at 12:14 PM
  • 110,251 POSTS
Have you had the TCM scanned for codes? Is the fluid clean and full?
Aug 17, 2010 at 5:57 PM
