1996 Ford Explorer Shift Solenoid C Performance or Stuck Of
165,000 MILES • 6 CYL • 4WD • AUTOMATIC
LARRYCTURNER
Hi, I seen a post on this site about this problem with a great little diagram of where all the parts are. I'm curious where shift solenoid C is on this Diagram. I need to replace it so my check engine light stays off and I can pass inspection. Also, will I need a gasket or rebuild kit since I'm going to have to drop the pan? And where do you find these parts? Thanks in advance for any help you can give me. - Larry
Aug 5, 2010 at 4:08 PM
  • 110,251 POSTS
I can't go by letters. Here is what I can tell you and I hope it helps. SS1 will have a gray wire foing to it, SS2 will have a brown wire go to it, and SS3 will have a yellow. All three will also have a white wire. The white is the power wire, and the others are the signal wires.
Let me know if this helps.
Aug 7, 2010 at 4:45 PM
