1996 Ford Explorer sensor
225,000 MILES • 4 CYL • 4WD • AUTOMATIC
ROBEQUINTERO
would anybody have any type of advice in changing a sensor fault. the sensor is
po136 sensor fault (bank 1 sensor 2)
po141 02 sensor heater fault (bank 1 sensor 2)
Mar 20, 2008 at 1:29 PM
FLEXY5
  • 512 POSTS
The sensor in question is the passenger side, rear sensor (after cat converter). But with both of those codes present, I would also inspect the wiring as well as the connector.
Mar 20, 2008 at 1:48 PM
