1996 Ford Explorer Overheating, loss of coolant, and loss o
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
DANIELWOELKI
The past two days my heat in cabin would work than go warm on and off. I was on my home from work and noticed the temperature gauge read about 90% up to the red danger line, so i pulled over and poured coolant in the overflow. I had filled it two weeks ago and looks like the overflow was empty. Could this be the thermastat? and if so how can I fix it?
Feb 11, 2009 at 4:31 AM
  • 110,248 POSTS
Hi:
the thermostat can cause a temp problem, but not a coolant loss. Does the temp go up even with the coolant full? Are you still loosing coolant? Check around the engine for leaks, the oil for evidence of coolant getting in it and let me know what you find.
Feb 13, 2009 at 1:16 PM
HELPING YOU
  • 100 POSTS
I'm wondering what "had it filled" means..could be you have just a bad cap and people have been adding to the expansion jug and not even checking the radiator?.(cap seal n/g during "contraction")
OR - If it was drained and filled there's a good chance no one took the time/effort and/or let it go through a warm-up cycle enough to get all the air "bled" out.
OR - Does "had it filled" mean it was low and not properly pressure checked and/or pressure checked and "no leaks found" @ that time?
Either way getting it hot most likely compromised the t-stat (even if it wasn't the problem) and it should be replaced. It's relatively easy to access if it's a 4.0 OHV (overhead valve). If it's a 4.0 SOHC (overhead cam) I wouldn't - the housing's plastic, harder to access and tend to leak if you're not careful...and a thin layer of silicone in the right place. Drill a tiny "bleed hole" in it if it doesn't have one.
Feb 13, 2009 at 2:02 PM
