1996 Ford Explorer Not enough heat
SUSIE1556
  • 1996 FORD EXPLORER
  • V8
  • AWD
  • 156,000 MILES
My explorer heat works sometime, we have chamge the thermostat and flushed the heater core checked heater valve and made sure there is enough antifreeze in it, but it still does not want to give heat. What is the problem?
Sunday, November 9th, 2008 AT 7:08 PM
BMRFIXIT
  • 19,053 POSTS
Do u hear any click noise under the dash
when adjusting the temp
and if so suspect blend door actuator
if engine reaching operating temp gauge in the middle if not suspect bad thermostat
check heater hoses if both hot, if not heater core need to be flushed again
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Tuesday, November 11th, 2008 AT 6:44 AM
