Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
General
Noises
Squeal
1996 Ford Explorer noise
1996 FORD EXPLORER
150,000 MILES • 6 CYL • 4WD • AUTOMATIC
DEANA
MEMBER
1 POST
there is a "squealing" noise when the car is started, noise goes away while driving but is there the next time it is started-any suggestions?
Jan 29, 2008 at 9:46 AM
TMANGT
MEMBER
Have your serpentine belt checked, if you are noticing no other problems, it is probably to tight.
Feb 2, 2008 at 3:24 PM
2CARPRO JACK
Experienced Mechanic
Have the tensioner inspected. Has the belt ever been repalced? They auto-tension so if the tensioner is worn it wont hold tight enough
Feb 3, 2008 at 11:51 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
