1996 Ford Explorer no brakes
170,000 MILES • 6 CYL • 4WD • AUTOMATIC
SPCHENDERSON
the brake pedal goes to the floor everytime and never stops the truck. checked the fluid, checked the master cylinder to see if i could press in the cylinder plunger, any suggestions?
Mar 31, 2010 at 12:16 PM
  • 110,248 POSTS
If the master cylender fluid is full, then there shouldn't be a leak. As a result, that leaves the master cylender as bad.
Apr 1, 2010 at 1:43 AM
