1996 Ford Explorer my suv wont start
MRFINCH2010
Engine Performance problem
1996 Ford Explorer 6 cyl Two Wheel Drive Automatic 157. miles
I tryed to jump it off, checked the fuses, check the connections, and it will try to start up but it dont!
Feb 9, 2010 at 2:18 PM
  • 75,988 POSTS
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Feb 9, 2010 at 2:39 PM
