1996 Ford Explorer my ABS keeps kicking in when I slow down
JONNEY304
  • 1996 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 200,000 MILES
My abs keeps kicking in when I slow down like at a light or stop sign I know it has something to do with the wheel speed sensor cuz I jus replaced the wheel barings is it a possibility I got some grease or dirt in it and I can clean it or do I absoloutley have to get a new one
Sunday, September 27th, 2009 AT 11:18 PM
LYNDON9
BAD WHEEL SENSOR. The front wheel sensors are reading 2 different speeds when you slow down thats giving you a "vibration" at the brake pedal. 2 things you can do. Replace both sensors or just disconnect the brake sensor cables. I had the same exact problem. Hope this helps.
Wednesday, October 28th, 2009 AT 7:51 PM
