I have a 1996 Ford Explorer XLT. It has the 4.0 v6 and sometimes the check engine light will flash. When it does the car will run really crappy. It will lose all power and spit and sputter and it will idle really bad. Then if you drive it for a while it will run perfect untill you shut it off. It dont matter if you shut it off and start it right back it will do the same thing. My ? is what would make it do this?
Jan 2, 2010 at 2:01 AM
