1996 Ford Explorer MIL/Check Engine Light
ADRIANA69
Electrical problem
1996 Ford Explorer 6 cyl Wheel Drive Type unknown Automatic 176883 miles
Hi, we had our car Smog check inspection report and it stayed that our car Failed MIL/Check Engine Light. Also, it said that car failed the MIL/Check Engine Light Test due to a Warning Lapm Failure.
In addition, it said OBD Fault Codes:
P0141 02 Sensor Heater Fault (Bank 1 Sensor 2)
We would like to know in which part of the car we can find this. and how we can fix it. I know I am asking for too much, but do you have this information in Spanish?
Feb 20, 2008 at 1:00 PM
BMRFIXIT
  • 19,053 POSTS
Sorry don’t speak Spanish
try in English
you need an O2 sensor its in the exhaust system
bank one is at the side where cylinder # 1 is
sensor 2 means its the 2nd sensor on that bank and its located after the catalytic converter
fire wall bank #1
radiator is bank #2
good luck
Feb 20, 2008 at 1:35 PM
