1996 Ford Explorer Ignition Switch
160,000 MILES • 6 CYL • 4WD • AUTOMATIC
RSPECK
My daughters vehicle would not turn off. Ignition switch failed-the switch itself would not turn the vehicle off. No resistance when turned. Are we looking at just the switch itself or more?Thanks
May 11, 2010 at 4:20 PM
BLUELIGHTNIN6
  • 16,542 POSTS
The most likely problem is a bad ignition switch. To find out for sure, remove the plastic covers over the steering column and remove the 2 screws holding the ignition switch in place. Make sure the mechanism coming from the key is turning the ignition switch. If the mechanism works fine, replace the ignition switch.
May 11, 2010 at 4:46 PM
