Engine Mechanical problem
1996 Ford Explorer 6 cyl Four Wheel Drive Automatic
My ford explorer won.t start , the fuel pump is defect
How can i change it ore how can i test it is there an manuel about the fuel system.
Is it possible that the fuel pomp is defect ,
Hope to get some help
Where is the fuel pump hiden, i think under the car near the fuel tank ???
But i can not find , do you need to remove the fuel tank ??
Apr 9, 2008 at 7:33 AM
