1996 Ford Explorer HELP ME PLEASE
250,000 MILES • 6 CYL • 4WD • AUTOMATIC
HOTRODS_2008
I HAVE A 1996 FORD EXPLORER THAT WILL NOT START. IT TRIES TO START AND WHEN IT DOES IT WILL ONLY RUN FOR ABOUT A MINUTE SOMETIMES TWO. I HAVE REPLACED THE FUEL FILTER AND CHECKED EVERYTHING THAT YOU CAN IMAGINE. I AM RUNNING OUT OF OPTIONS AND IDEAS. ANY HELP THAT YOU CAN GIVE ME WOULD BE GREATLY APPRECIATED.
THANKS!
Nov 14, 2008 at 5:50 AM
IMPALASS
  • 3,112 POSTS
Hello
Based off of the miles you have I would say it is your fuel pump. You need to perform a fuel pressure check. But again, based on the miles. I would think the pump. If you do, replace the fuel pump relay also.
Nov 14, 2008 at 5:08 PM
