1996 Ford Explorer help
MICHAEL RAY
Engine Mechanical problem
1996 Ford Explorer 6 cyl Four Wheel Drive Automatic
our explorer was running but a little hesatant and now it wont start the only way it will is if you spray fuel in the carburator but it dies when it runs out we have replaced the fuel pump and filter,camshaft position sensor and it has a new battery and all fuses are good can you help?
Apr 22, 2008 at 7:48 AM
MERLIN2021
  • 17,250 POSTS
When you turn the key to on, do you hear the fuel pump in the gas tank run for 2-3 seconds? If not you'll need to check the relay under the hood. The inertia switch, this cut fuel in an accident, but can be tripped or defective, and is located on the passenger side kickpanel, remove the trim panel and try holding the button down. Last, it can be a bad wire to the pump, or ignition switch, some activate the injectors when in the crank position, this is why you need to see if the pump runs!
Apr 22, 2008 at 8:09 AM
