1996 Ford Explorer Heater control
80,000 MILES • 6 CYL • 4WD • AUTOMATIC
GARYMILES
When I turn the temperature control knob, nothing happens to the temperature. It is stuck on high heat. I don't think it is the blend door becasue even when the AC is turned on the air doesn't stay hot, is just doesn't get cold.
Feb 16, 2010 at 2:40 PM
  • 110,248 POSTS
It sounds like the blend door isn't working properly. It may be partially stuck.
Feb 17, 2010 at 12:39 AM
