Check fuses #4, #8, and #33 on your fuse panel at the instrument panel, and fuse #11 at the power distribution box under the hood. According to the schematic, there is no relay.
If the fuses are OK, there may be a problem with a connector (corroded contact or pin pushout) or a broken wire in the harness. The color code of the wire is WHITE with LIGHT GREEN trace.
SPONSORED LINKS
Monday, May 10th, 2021 AT 1:24 PM
