1996 Ford Explorer gas
174,000 MILES • 6 CYL • 4WD • AUTOMATIC
RASCOTT
my gas meter works but it is not accurate, it will tell me i have eight gallons left but it runs out of gas before time to refuel.
Apr 4, 2010 at 11:19 AM
  • 110,248 POSTS
Chances are either the float in the tank is sticking or there is a problem with the body control module. I would start by having the BCM checked so you don't have to remove the tank unless it is truly necessary.
Apr 5, 2010 at 6:23 AM
