1996 Ford Explorer fuel pump system
115,000 MILES • 6 CYL • 4WD • AUTOMATIC
CARY77
My ford died on me the other day, i sent it to my wifes dads shop he put in a new fuel pump, then a pcm. still wouldn`t run right, you turn the ignition and the fuel pump kept running and the relays under the hood were clicking. I sent it to the local ford shop, they ended up putting a new fuel pump in it. anyway i get it home and it does the same thing the next morning when i try to start it. the symptoms are the same and when you drive it it idles really high and it will just fall in and out of gear, but if you shut it off and on several times it will run fine. do you have any idea what is going on?
Jan 1, 2008 at 4:00 AM
T-MAN
  • 9 POSTS
sounds like faulty relays under the fuse panel on fender well...i had same issue,replaced relays fixed problem
Feb 16, 2008 at 9:48 PM
