1996 Ford Explorer fuel pump replacement
BILLDJ1
Electrical problem
1996 Ford Explorer 6 cyl Two Wheel Drive Automatic
My car cranks but will not start. I do not hear the fuel pump when I turn the ignition switch on.
Mar 9, 2009 at 9:30 AM
BLUELIGHTNIN6
  • 16,542 POSTS
First inspect your fuses and relay before turning to the pump itself.
Thanks for using 2CarPros.com!
Mar 9, 2009 at 9:40 AM
BILLDJ1
Thanks, I checked the fuses and replaced the relay. No change. I will have the fuel pump replaced and will let you know the results.
Mar 10, 2009 at 6:40 AM
