1996 Ford Explorer fuel pump
146,000 MILES • 6 CYL • 4WD • AUTOMATIC
MOPARNUTS
is there a way to replace fuel pump on 96 explorer with out removing gas tank?
Jan 30, 2008 at 2:15 PM
PARIDGERUNNER
  • 5 POSTS
No way I know of, without cutting hole in floor above pump. They don't make it that easy anymore. Make sure you drain tank BEFORE you remove it, and don't smoke while you are working on it.
Feb 11, 2008 at 1:27 PM
