Is there a way to replace fuel pump on 96 explorer with out removing gas tank?
Wednesday, January 30th, 2008 AT 10:15 PM
PARIDGERUNNER
MEMBER
No way I know of, without cutting hole in floor above pump. They don't make it that easy anymore. Make sure you drain tank BEFORE you remove it, and don't smoke while you are working on it.
