1996 Ford Explorer fan clutch removal
REKEY
Engine Cooling problem
1996 Ford Explorer 6 cyl Two Wheel Drive
I have the removal tool for the clutch fan.I do not see where the (pins or screws go to hold the shaft from turning , while I loosen the collar nut. Help me if you can. Pictures are nice also.
Thank you for your time. Rick in need.
May 25, 2010 at 9:55 AM
  • 31,937 POSTS
Hi there, Thank you for the donation. Looking at Mitchell 1 data base, on this model there are 2 tools required to unscrew the clutch, the thread is Left handed as well see pic for a better idea as to what is needed.
https://images.2carpros.com/forum/automotive_pictures/61395_Graphic_145.jpg
Mark (mhpautos)
May 25, 2010 at 11:12 AM
