1996 Ford Explorer EVAP EMISSION CAN PURGE FAULT
10,778 MILES • 6 CYL • 4WD • AUTOMATIC
KENMECH
Hi I have carried out an OBD11scan because my sevice light came on the fault code is evap emission can purge fault, i can clear the fault and it will last from 2 days to 2 weeks but comes back on again. So my question is where is this part and what are the repair procedeures. thanks Ken
Mar 5, 2008 at 8:53 PM
2CARPRO JACK
  • 11,533 POSTS
Procedure needs to b efollowed to figure out EVAP issues. Go here
https://www.2carpros.com/articles/mitchell1eautorepair-car-repair-manuals
Full instructions on diagnosing the problem. Be aware it may come down to a smoke machine, to find the leak (if that is the direction diagnosis takes you)
Mar 6, 2008 at 4:33 AM
