1996 Ford Explorer ega valve
120,000 MILES • V8 • 2WD • AUTOMATIC
RDWOODAR
how to replace
Dec 28, 2008 at 9:54 AM
DAVE H
  • 13,383 POSTS
EGR VALVE
Removal & Installation
Disconnect the vacuum hose from the EGR valve. Disconnect the EGR valve to exhaust manifold tube from the EGR valve. Remove the EGR valve bolts and the EGR valve. Remove the EGR valve gasket and clean gasket sealing surface. If the old EGR valve is to be installed, clean the gasket sealing surface. To install, reverse removal procedure.
Dec 28, 2008 at 10:44 AM
