1996 Ford Explorer ega valve
RDWOODAR
  • 1996 FORD EXPLORER
  • V8
  • 120,000 MILES
How to replace
Sunday, December 28th, 2008 AT 5:54 PM
DAVE H
  • 13,383 POSTS
EGR VALVE
Removal & Installation
Disconnect the vacuum hose from the EGR valve. Disconnect the EGR valve to exhaust manifold tube from the EGR valve. Remove the EGR valve bolts and the EGR valve. Remove the EGR valve gasket and clean gasket sealing surface. If the old EGR valve is to be installed, clean the gasket sealing surface. To install, reverse removal procedure.
Sunday, December 28th, 2008 AT 6:44 PM
Related General Content
