1996 Ford Explorer distributor and timing
1996 FORD EXPLORER
11,300 MILES • 6 CYL • 4WD • AUTOMATIC
DENNIS ELAM
How to remove and replace the electronic distributor module ( how to set distributor correctly in th proper timing gear, then bolt down )
How to set the timing ?
Jan 7, 2009 at 8:01 AM
JGAROFALO
  • 489 POSTS
All Explorers have distributor-LESS ignition. There is no timing setting. There is a camshaft position sensor on the rear of the engine on the 4.0 pushrod engine, but this is not meant to be a timing adjustment. If you have removed the drive unit, you will need to follow a rather lengthy procedure to bring the engine back into time.
Jan 8, 2009 at 2:24 PM
