1996 Ford Explorer clunking noise
10,300 MILES • 6 CYL • 4WD • AUTOMATIC
EARNHARDT811162
i replaced the driveshaft and yoke, and i changed the tranny fluid and screen,and the rear end oil. the problem is when i start off driving from first to second it clunks and after that it shifts fine but when i go to stop right before it does it clunks again. also the rear end does have so what play in it. is it the rear end?
Jun 13, 2010 at 2:08 AM
  • 110,248 POSTS
Before I say it's te differential, are you sure the trans mount and motor mounts are good? Also, are the shackles ( where the leaf spring bolts to the frame) in good shape. They all rust and break leaving the axle only partially attached to the frame.
Jun 14, 2010 at 8:20 AM
