1996 Ford Explorer battery light
199,805 MILES • 6 CYL • 2WD • AUTOMATIC
BRYAN KILE
battery light is on .i change alternator. the battery is good. can find problem
Sep 5, 2010 at 3:12 AM
  • 75,988 POSTS
Check fuse no.17 15amp in the power distribution box and fuse no. 15 15amp in the interior fuse panel, both this fuses okay -start checking the wires back to the ignition switch thru the charge indicator
Sep 5, 2010 at 6:12 AM
