battery light is on .i change alternator. the battery is good. can find problem
Sep 5, 2010 at 3:12 AM
✓Experienced Mechanic
Check fuse no.17 15amp in the power distribution box and fuse no. 15 15amp in the interior fuse panel, both this fuses okay -start checking the wires back to the ignition switch thru the charge indicator
