hi there my air con keeps going onto the defrost no matter where you set it could you give me some advise on this matter thankyou don
Jan 23, 2010 at 9:52 AM
✓Experienced Mechanic
I feel confident that you are looking for a vacuum leak in this case. The vent doors are actuated by vacuum. THe defalt setting is the defroster if there is a leak. Check under the dask for leaks. If you have the engine running, you may actually hear a hissing sound from a leak.
