1996 Ford Explorer abs
RICANREAPER
Brakes problem
1996 Ford Explorer 6 cyl Four Wheel Drive Automatic
abs light came on recently what does it mean[img:6377a1654b]http://www.2carpros.com/forum/automotive_pictures/193779_junito_car_1.jpg[/img:6377a1654b]
May 24, 2008 at 5:00 AM
  • 31,937 POSTS
Hi there,
The ABS system has lodged a fault code, you will need to scan the system and retrieve the code. With this information your Tech will be able to locate the problem . This may be a problem with a wheel speed sensor.
Mark (mhpautos)
May 24, 2008 at 5:56 PM
